Got bored sitting with a spliff, so did a quick look. Here's a bit if science on the matter:
https://www1.health.gov.au/internet/mai ... 2-ch52.htm
The article states that thc has the highest toxicity and suggests that a lethal dose of delta9-THC is about 8,45 kg for a 60 kg adult. Sounds around the numbers I've read / heard before.
So, even if you have ridiculously potent weed at 30 % thc and you could effectively get every last mg of thc in to your blood stream (by some miracle way of consuming with no physical or biological losses under way), you would need a bit more than 28 kgs and you would need to consume it fast enough for it to be present in your blood stream at that concentration. IIRC these numbers do not account for tolerance, so if you have build tolerance the LD50 goes up.
Now, I know there's some very serious potheads on this forum, and that I've been guilty of overindulgence on more than one occasion, but those amounts are too tall an order for the whole gang going at it for a week, so I'll stick to my original thoughts that while an interesting conversation starter, there's probably a bit too much "wiki-science" behind the data for it to be a reliable source of information.
I agree that the overall message of the chart is worth noticing, and worth talking about, but would just wish that no numbers were given as they can quickly lead to people making the wrong conclusions. By this I mean that the chart (or more specifically the data) can be used to make the argument that if you can feel 0.1 of a gram of a cannabis product, 1 gram of that is a lethal dose and consequently something that should be regulated further...
