Dutch Rail to reduce train toilets
Monday 07 July 2008
The number of toilets in trains and on railway stations is to be drastically cut back, the Telegraaf reports on Monday.
Passenger groups are already demanding transport minister Camiel Eurlings take action about the lack of loos, the paper says.
Dutch Rail (NS) says scrapping toilets allows it to build four extra seating areas in a train. The toilets are also rarely used, the company says.
Source
Monday 07 July 2008
Source
Cannabis is The Tree of Life
itsmymagicallife
- OneForTheRoad
Have any of you ever used the toilet on a train? Generally they are very very gross and only used as a very last resort. When you flush, it empties onto the tracks. Yes, you can look down through the toilet and see the ground going by. So they either need to be modernized like the ones in the stations or eliminated. The way they are now is not good.
never on the train as i am more interested on counting the minutes until the 1st CS. But if this is the case with the toilets emptying on2 the tracksmilehigh wrote:Have any of you ever used the toilet on a train? Generally they are very very gross and only used as a very last resort. When you flush, it empties onto the tracks. Yes, you can look down through the toilet and see the ground going by. So they either need to be modernized like the ones in the stations or eliminated. The way they are now is not good.
have used the ones at Central station just up from the luggage lockers and they are okay but then you pay for these.
Nice1
On the track is proper dirty
You do realise where it goes on a plane right?Kermit wrote:never on the train as i am more interested on counting the minutes until the 1st CS. But if this is the case with the toilets emptying on2 the tracksmilehigh wrote:Have any of you ever used the toilet on a train? Generally they are very very gross and only used as a very last resort. When you flush, it empties onto the tracks. Yes, you can look down through the toilet and see the ground going by. So they either need to be modernized like the ones in the stations or eliminated. The way they are now is not good.then they should get rid and quick.
Nice1
courtjester
