Previous Posts
Post tips here on how to join, how to post pictures, etc.
chilly1952
Previous Posts
Post by chilly1952 »
I see previous post put into a new post and the new comments below. How do you do that?????
Re: Previous Posts
chilly1952 wrote:I see previous post put into a new post and the new comments below. How do you do that?????
Like this?
Press the quote button (far right>>>) of the previous post you want in your post.
chilly1952
Re: Previous Posts
[quote="Boner"][quote="chilly1952"]I see previous post put into a new post and the new comments below. How do you do that?????[/quote]
Like this?
Press the quote button (far right>>>) of the previous post you want in your post.[/quote]
Thanks, Mr. B.
chilly1952
OK what did I do wrong???????
Puffin13
Re: Previous Posts
Post by Puffin13 »
Just click on the "quote" button, in the upper right hand corner of the message, chilly. That's the easy way, without having to use html (hyper text markup language).
Cannabis is The Tree of Life
Twitch
Post by Twitch »
chilly1952 wrote:OK what did I do wrong???????
like this
Old School and Proud of It.
Lemming
Site Admin
Post by Lemming »
You need to make sure that you have "allow BBCode" switched on in your profile or the post. It is on by default but if you turn it off then quotes, URLs, etc. won't work (you can't use real HTML, incidentally, even with this turned on). chilly1952 - it looks like you've turned off BBCode in your profile. Let me know if you need help turning it back on.
Ghost
Post by Ghost »
Just seeing if i could do it seems easy enough.
Lemming wrote:You need to make sure that you have "allow BBCode" switched on in your profile or the post. It is on by default but if you turn it off then quotes, URLs, etc. won't work (you can't use real HTML, incidentally, even with this turned on). chilly1952 - it looks like you've turned off BBCode in your profile. Let me know if you need help turning it back on.
angry pirate
Post by angry pirate »
what about just quoting part of a post? never did figure that one out.
Free to join :)
angry pirate wrote:what about just quoting part of a post? never did figure that one out.
Quote the post and then just delete what you dont want, so if I just want part of the one above I can change it to this:
angry pirate wrote:never did figure that one out.
angry pirate
that was the first thing i tried! dunno how , but i ballsed it up then. cheers b.
Free to join :)
StonedSince67
Post by StonedSince67 »
angry pirate wrote:that was the first thing i tried! dunno how , but i ballsed it up then. cheers b.
just have another go
find a short and simple message in this thread with no other quoted bits in it
then quote it and type something like 'EASY STUFF' in the middle of the message
for example
angry pirate wrote:that was the first thing i tried! EASY STUFF dunno how , but i ballsed it up then. cheers b.
then select the Preview button to see what your edit looks like
then select the Submit button to post your message
tastywaves
Post by tastywaves »
Thanks for the input Lemming, I had the same problem as Chilly. Thanks again.
Pass the peace pipe.
angry pirate
StonedSince'67 wrote:just have another go
cheers ss, yeah, worked first time. dunno what went wrong last time, thought i'd deleted all i didn't need, but when i posted, it was all still there. weird. should've previewed it really. :)
Free to join :)
