Just got back..had a good time. However, I mostly smoked hazes and while I smoked a LOT they didn't really knock me out much except for the first night...when I had smoked a LOT.
Tried:
NYC Diesel- Greenhouse- shiite
Amnesia Haze- Rookerij- OK, just okay
G-13 Haze- Barneys- kicked my ass the first night, after that kept me mostly fidget-y
Laughing Buddha- Barneys- again okay but still I felt pretty normal
Red Dragon- Finally a weed that felt like weed generally does
Could it be that I am just much better suited for Indicas????? Until I tried the Red Dragon I couldn't really relax. I felt all tense.
Any thoughts and/or advice on Indicas to try would be greatly appreciated.
Can one be immune to hazes????
vivalamata
- Trichome_Dense
murphyscafe
Hazes get you high, and if they have a clear high, then often people won't understand they are high, because you don't feel any different. It's hard to explain. If you want to know you are stoned, you smoke an Indica and you get stoned. Many people smoke hazes and because of the uplift, they don't feel like it has had any effect.
Also in some strange occassions, people go a long time before the weed really hits them, but when it does, it's always fun.
Just trying to be 'En Vogue'
vivalamata
Sounds like indica is more your style. Hate to recommend the most recommended weed, but sounds like SSH might be your ticket. It's a 50/50. Black Widow from Katsu. Here are some others, but I'm not quite sure where to find them: MK-Ultra, Big Buddha's Blue Cheese, Kushes, any G13 or G13 haze crosses (Soma's Sogouda), Sour D, Kali Mist (which has haze in it, but is far from clear headed) or White Russian. Some strong hash or iso hash might do the trick.
- Viking Weed
The S5 Haze from MY is pretty nice. It's a bit too racy for me, but if you're looking for a nice haze, that's definitely an option.
If you figure that you're more into indicas, then I recommend the LA Confidential. This should be available at several shops. I can vouch for the LA Con from both Grey Area and Mellow Yellow as usually being good. I think the Green Place and Bluebird also have this on the menu, though I haven't tried them.
