Jamaican High Grade / Sess with vaporizer?
davetherave
Post by davetherave »
Just seeing if anyone has had any experience of using Jamaican high grade/sess with a vaporizer? I want to try but am worried it will be a waste of cash as I do not have much experience with a vaporizer.
Any vaporizer recommendations and tips or techniques would be helpful, cant seem to find much info as it all relates to using skunk.
I want to cut out tobacco, and am guessing this is the best option? Just hoping to get the same affect or stronger.
Thanks
EasilySuede
Re: Jamaican High Grade / Sess with vaporizer?
Post by EasilySuede »
davetherave wrote:Just seeing if anyone has had any experience of using Jamaican high grade/sess with a vaporizer? I want to try but am worried it will be a waste of cash as I do not have much experience with a vaporizer.
Thanks
hey dave, which vapo are you using? If you're using an "automated" model (eg, Volcano, etc.) you probly won't have any waste issues. But if you're using a vapo that requires some finesse, where you "have to do the work", you may want to use less special herb until you get the "feel".
davetherave
I am yet to decide on a vapo, but looking at either launch box or the arizer extreme. want to be 100% sure before parting with my money
EasilySuede
davetherave wrote:I am yet to decide on a vapo, but looking at either launch box or the arizer extreme. want to be 100% sure before parting with my money
hey dave-
Using ye olde Amazon...
http://www.amazon.com/Latest-Model-Magi ... words=mflb
I'm thinking about the MFLB myself, for something portable. Units like this simply make heat, you provide the airflow thru the ground herb. Takes awhile to get used to this approach, 'cause you have to slooowly draw air thru the unit in order for it to get properly heated enough to evaporate the thc/cbd/etc.
motorized units, such as below, don't require controlled breathing...
http://www.amazon.com/Arizer-Extreme-Q- ... er+extreme
dunno if this thread would help...
https://www.coffeeshopdirect.com/forum/viewt ... 40#p286140
enjoy
PecosTheCat
Post by PecosTheCat »
Any vape should give you better mileage than combustion in my experience. For cheap n cheerful the mflb is hard to beat. If you can stretch the budget and don't need stealth, check out the ArizerSolo.
oooh aaar traktor
Post by oooh aaar traktor »
I took the plunge with my first cape, a silver surfer off eBay for about 70 quid.
Its amazing! Even standard u.k Thai hits the spot. Didn't take too long to get the hang of it. We were smaaheh in about 20 mins after cleaning it up :)
davetherave
kkchome wrote:Any vape should give you better mileage than combustion in my experience. For cheap n cheerful the mflb is hard to beat. If you can stretch the budget and don't need stealth, check out the ArizerSolo.
Yh the arizer's look good but the solo is similar price to the extreme, I am not bother about it being portable.
oooh aaar traktor wrote:I took the plunge with my first cape, a silver surfer off eBay for about 70 quid.
I like the sound of this, I am not to keen on thai anymore since the disappearance of amazing thai stick from a fair few years back. But will be up for giving it a go again if the vapo brings out the best in it.
Would like to try some solid in this as well cause there is some really nice solid around but not keen on smoking it in joints.
