/o
- bluelaru
I have been watching the infomercial for Aerogarden....
anyone else.....
its very tempting....it looks like the only down side...is...youd be limited to the size by height.....
This item is related...because....its a self contained growing system
in water...with a lite source...
so....Anyone...else see....or have....input
anyone else.....
- Twitch
Looks interesting, but expensive.
http://www.sunlightsheds.com/turn_key_units.htm
Old School and Proud of It.
- AL
Re: L.E.D. Growlights
stew1974 wrote:hi seen these advertised on ebay and wondered if anyone has used them to grow. I understand great idea but are they effective? Yes they reduce heat greatly and electric used but do they work. The ones i have seen have three downlights 2 red 1 blue. Can you get all blue for vegetative stage and red for flowering? or do they work adequately as a mixture?
led forget it you,ll be harvesting your megre crop maybe this time next year bud
need a spliff......
- AL
at least 400+ watts bud,if your planning to grow 5-6 plants,also need rvk fan,carbon filter,ducting,mylar,oscilating fans,nutrients,medium(soil),reflectors,probably 11ltr pots,pebbles for bottom of pots(helps drainage and air flow etc),couple more bits&bobs,then a lotta PATIENCE.stew1974 wrote:Thanks for replies , it sounded nice in theory! never grown , interested for years and now have house with spare room. hoping to start next month so doing lots of research. good to get answer from respected and knowledgable posters or might have been tempted! Hoping to grow 5-6 plants for personal. Thinking about white russian and my present quandry is will i get away with 250W or should i go for 400W at least?
need a spliff......
- AL
might be changing my views on led lighting as reading our local soft secrets paper it had an article on this subject & seeing its NASA thats behind the scheme (if it wasnt for nasa & the russians hid lighting would have taken longer to appear on the scene)im keeping an eye on itstew1974 wrote:hi seen these advertised on ebay and wondered if anyone has used them to grow. I understand great idea but are they effective? Yes they reduce heat greatly and electric used but do they work. The ones i have seen have three downlights 2 red 1 blue. Can you get all blue for vegetative stage and red for flowering? or do they work adequately as a mixture?
need a spliff......
Rubbish
These L.E.D lighting systems are rubbish do not buy them. You need to spend alot of cash to yield what a 600w Hps can yield.
Go for A Lumnatek Digital ballast and either an Adjust Shade or a Mantis reflector with Osram Son T Lamp.
Very very Good
Couple that with A coco setup in a 20mm irrigation system and you will be flying!!!!!!!!!!!!!
Very very Good
- Puffin13
Re: Rubbish
What kind of experience have you had with the LED grow lights? Did they not work for you? Why not? Can you give us more info than "they are rubbish"?Kermit wrote:These L.E.D lighting systems are rubbish do not buy them. You need to spend alot of cash to yield what a 600w Hps can yield.
Very very Good
Thanks. Peace.
Cannabis is The Tree of Life
L.E.D
I worked in a quite well known hydro shop for 5 years up until a year ago when i left to become a full time parent. We have had demo models of these Lighting systems comming in all the time. They Just do not perform and are not value for money. They are tested alongside other systems and even CFLs are better. Try them for yourself and compare i was being helpful.
Thanks
Thanks
- DazedandConfusedinOR
I think there is a misconception about the aerogarden. Sure, it won't compare to MH or HPS setups, but it's not meant to. It's for growing herbs and tomatoes! The most successful aerogarden grows I've seen have produced about 1/2 to 3/4 of an ounce per plant. Realistically, you can only grow 2 lowriders at a time as the plants will compete for light and nutrients. Additionally, the aerogarden reservoir is only 1 gallon (a bit less actually). On the other hand, it only uses about $3 a month in electricity which can be a concern for many growers. Anyway, that's my 2 cents!bluelaru wrote:I have been watching the infomercial for Aerogarden....
anyone else.....
I currently have an aerogarden grow going (planted 5/1/10) so I'll keep you guys posted!
